If you drag a square selection into the window edges, the window scrolls when the cursor meets the edge, but not the left edge specifically when maximised (it does when non-maximised). Also the scrolls are performed at different speeds depending on the edge.
* Dragging the selection to the left edge of a maximised window should scroll also.
* Scrolls should happen at consistent speeds for all edges (unless there's a logistical image decoding barrier to achieving that).
* In addition, I wonder if it's possible for this topic about slow crops to be moved to the Bugs section for processing as I think it's best viewed as a bug - viewtopic.php?p=210403
Selection To-Edge Drags (inconsistently occurring, inconsistent speeds)
meteorquake
Re: Selection To-Edge Drags (inconsistently occurring, inconsistent speeds)
also, in Fullscreen selection does not scroll image at all
This problem is supposed to be fixed in XnView MP 1.11.4. Please check and confirm the bug fix here.
