Bug if use option create sheet and interface theme
Xn User
Post by Xn User »
Hi Pierre )
I'm detect bug ) if I use XnViewMP with include xnview.ini in folder with XnViewMP , so after this actions , damage interface theme in version 1.9.6 and later , this fixable if I return old ini file , however , after next this actions , all retry https://www.mediafire.com/file/7v3xm8mt ... 4.avi/file , this files need put in a folder with portable version or in install folder https://www.mediafire.com/file/yrru7v2l ... i.zip/file
Re: Bug if use option create sheet
Sorry but where is the problem in contact sheet??
Xn User
Post by Xn User »
Problem with interface after use this option or use options with settngs , sorry if I made a mistake in the name ) in version 1.9.5 this error absent )
ok, but which problem?
Xn User
Post by Xn User »
In video all showed , you can see as breaks down interface after actions from video ) , important , for this need extract in XnView files from two artchve , and not use settings with skin c:\Users\user\AppData\Roaming\XnViewMP\ , there need leave only XnView.db and Thumb.db )
