Image copying fails to display
alee001
Post by alee001 »
Every time I drag and drop two or more JPG images from File Explorer to my MP folder, one image always fails to display in the browser thumbnails (as shown in the image). I have to press F5 to update to fix it. Is there a problem?
P.S. Windows XnView MP, any version
alee001
Re: Image copying fails to display
Post by alee001 »
Additionally, when searching for a folder using the quick filter, version 1.9.8 sometimes fails to display some thumbnails (as shown in the image above). Pressing F5 to update resolves the issue and displays all thumbnails correctly. (This problem did not exist in previous versions.)
alee001 wrote: Tue Dec 09, 2025 8:47 am Every time I drag and drop two or more JPG images from File Explorer to my MP folder, one image always fails to display in the browser thumbnails (as shown in the image). I have to press F5 to update to fix it. Is there a problem?
Every time? Please send us your xnview.ini
alee001
Post by alee001 »
xnview wrote: Sat Dec 13, 2025 9:16 am
1) I found that dragging and copying JPGs works fine under normal circumstances; the problem only occurs with JPG files saved from Photoshop.
2) When quickly filtering to find the folder I need, there are more problems when the folder contains a large number of files (over a thousand).
3) When a PNG image is converted to a JPG using Ctrl+U, the thumbnail cannot be displayed correctly. You must press F5 to update and it will be displayed correctly.
please send us sample files
alee001
Post by alee001 »
xnview wrote: Sun Dec 14, 2025 9:41 am please send us sample files
A video is attached for reference.
1) Select a PNG image and press Ctrl+C, then Ctrl+V to copy the image; the thumbnail doesn't display.
2) Press F5 to update and it should display correctly.
3) Select the copied PNG image and press Ctrl+U to convert it to JPG; the thumbnail still doesn't display.
4) Press F5 again to update and it should display correctly.
with you .ini and a png i can't reproduce, please send a PNG sample
alee001
Post by alee001 »
xnview wrote: Tue Dec 16, 2025 9:39 am with you .ini and a png i can't reproduce, please send a PNG sample
I've tried with any PNG image and the result is the same.
Cases 1 & 2 occur intermittently and I cannot reproduce them.
Case 3 PNG image only occurs in v1.9.8; it did not occur in previous versions.
alee001 wrote: Tue Dec 16, 2025 1:29 pm Case 3 PNG image only occurs in v1.9.8; it did not occur in previous versions.
you are able to reproduce each time?
alee001
Post by alee001 »
xnview wrote: Thu Dec 18, 2025 3:17 pm
Yes, JPG files have the same problem. Please watch the video again.
alee001 wrote: Thu Dec 18, 2025 4:28 pm Yes, JPG files have the same problem. Please watch the video again.
It's a copy/paste of file in XnView? Win10 or Win11?
alee001
Post by alee001 »
xnview wrote: Fri Dec 19, 2025 8:42 am
In Windows 11 pro, select any image in MP and press Ctrl+C and Ctrl+V.
I can reproduce
1. open folder with images in Browser
2. set FilterBy to Images OR Images (+folders)
3. copy/paste image into the same folder multiple times
ps. also there were translation issues of 2 strings related to with 'Copy (#) of <Filename>' option (incorrect variables order)
alee001
Post by alee001 »
Case 2: After a random folder search, some thumbnails (such as videos) cannot be displayed when accessing the folder (random).
alee001
Post by alee001 »
I reproduced the situation of case 1 as shown in the video.
