1.9.8 - browser - album - issues with adding objects
XnViewMP 1.9.8
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Browser - album
Issue A
its possible to add folder into Album (via drag&drop), but
in Metadata menu this option is grayed when folder is selected
Issue B
its not possible to add object into parent Album
Issue C
its possible to drag&drop into Album from win file explorer, but this operation leads to impossible copy dialog
so it either should
- auto-import object into Catalog and add it to Album OR
- just block this operation completely (show cursor w/ prohibited symbol)
Related
