1) Select an image in the browser and double-click the left mouse button to enter the editing window.
2) Press Page Down to go to the next image or Page Up to go to the previous image.
3) Press Esc to exit the editing window.
4) The result in the browser still shows the image position selected before entering the window .
No position update, Is this a problem or could be improved for win v1.9.8?
Image selection update ineffective
Re: Image selection update ineffective
check 'Select file in Browser when Viewer tab is closed' in Settings>Interface
alee001
Re: Image selection update ineffective(Resolved)
Oh, that was the setting. Thank you for your help.user0 wrote: Tue Dec 16, 2025 8:45 am check 'Select file in Browser when Viewer tab is closed' in Settings>Interface
