hi helpers :-)
how to set the sorting options (or any else), if i'd like to browse the searchresults (ctrl+f,enter,enter) in the exact order of the directories/pathnames/filenames, the files are found?
i don't see any way to do that.
în other words, i'd like to browse the pictures in the same order, as if they were found on the harddrives.
browse searchresult in exact order of dirs/path/filenames?
loth
Dreamer
So you want 'sort by path (directory>filename)' option, not just 'sort by filename' right?
E.g.:
and you don't want this:
but this:
I think it's not possible.
I support this request ('sort by path' option). Path could be shown also in result file list, in details view maybe.
E.g.:
but this:
