When using NConvert to process a 14369×5291-pixel monochrome BMP bitmap, the x64 version crashes when rotating by 90° or 270°, while rotation by 180° works normally. Tests have shown that:
All 32-bit versions function properly.
NConvert-6.88-win64 works normally.
NConvert-6.92-win64 crashes, and all newer 64-bit versions also crash.
C:\Users\Administrator\Desktop\test>nconvert.exe -rotate 90 -o output.bmp -overwrite input.bmp
** NCONVERT v7.226 (c) 1991-2025 Pierre-E Gougelet (Jun 17 2025/15:11:26) **
Version for Windows 7/8/10/11 x64 (All rights reserved)
** This is freeware software (for non-commercial use)
C:\Users\Administrator\Desktop\test>nconvert.exe -rotate 180 -o output.bmp -overwrite input.bmp
Conversion of input.bmp into output.bmp OK
C:\Users\Administrator\Desktop\test>nconvert.exe -rotate 270 -o output.bmp -overwrite input.bmp
The x64 version crashes when rotating by 90° or 270°
gy0715
Re: The x64 version crashes when rotating by 90° or 270°
are you able to reproduce with 7.228?
gy0715
Could you tell me where I can download Version 7.228? The latest version available on the official website is Version 7.226, isn't it?
the version on website is 7.228gy0715 wrote: Mon Jan 05, 2026 11:01 am Could you tell me where I can download Version 7.228? The latest version available on the official website is Version 7.226, isn't it?
gy0715
The version of this link is v7.226, and the modification time is June 17, 2025.
https://download.xnview.com/NConvert-win64.zip
i can reproduce the crash...
