I would like to set the white background of an icon file to invisible. Can I do that? The edit color map option is greyed out and cannot be used.
Thanks.
Creating invisible layer in icon (.ico) file
Re: Creating invisible layer in icon (.ico) file
If you use .ico format, sorry but you can'tonix wrote:I would like to set the white background of an icon file to invisible. Can I do that? The edit color map option is greyed out and cannot be used.
