Bugs which are supposed to be fixed in the next test version (not available yet)
Moderators: xnview , Dreamer
dernik
Posts: 5 Joined: Thu Mar 16, 2023 12:48 pm
Post
by dernik » Fri Jan 09, 2026 10:42 am
If a folder contains many files that don't all fit on one screen, then after we scroll all the files to the very bottom of the screen, the upward scrolling stops working. The wheel doesn't respond at all.
v.1.9.8
Added: this is only observed when this slider is set to 13. There are no problems with other values.
Posts: 2996 Joined: Sat May 09, 2015 9:37 am
Post
by user0 » Fri Jan 09, 2026 5:40 pm
I can reproduce
1. set Thumbnail cell spacing to 10
2. resize filelist height to fit at least 2 rows of thumbnail cells with spacer
3. scroll to the end of the list
Posts: 47878 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Mon Jun 15, 2026 4:43 pm
do you have it always in 1.11.2?
Post
by user0 » Mon Jun 15, 2026 4:47 pm
xnview wrote: Mon Jun 15, 2026 4:43 pm
yep
scrolling up over file list area stops working once the end of the list is reached
scrolling up over scrollbar work normally
Kadet
Posts: 236 Joined: Thu Oct 20, 2022 7:23 pm
Post
by Kadet » Mon Jun 15, 2026 6:07 pm
I reported this ages ago but Pierre did nothing about it. You can scroll up when you move the cursor to the right on the side scroll bar.
Post
by xnview » Tue Jun 16, 2026 5:39 am
could you send me a .ini to reproduce?
Post
by user0 » Tue Jun 16, 2026 5:42 am
try this one
xnview_scrolling_up.zip
Post
by xnview » Wed Jun 17, 2026 6:01 am
Thanks to your detailed description I can reproduce
the problem .
