Image copy name incorrect
alee001
Post by alee001 »
Immediately after updating MP to version 1.9.9, an error was found in the copied image name (see image). Please follow up.
Re: Image copy name incorrect
change 'Duplicate files naming' to any other option
in Settings>General>File operations
alee001
Post by alee001 »
user0 wrote: Mon Jan 12, 2026 9:32 am change 'Duplicate files naming' to any other option
This is a translation error between the English and Chinese copy names.
alee001 wrote: Mon Jan 12, 2026 9:44 am This is a translation error between the English and Chinese copy names.
What is the good translation?
what error? words in last options should be in this order: "Copy" (#) "of" <Filename>
translation - order of variables
alee001
Post by alee001 »
xnview wrote: Mon Jan 12, 2026 9:51 am
I suggest you use a translator! :?
so
like that?
Extension should be at the end....
xnview wrote: Mon Jan 12, 2026 1:25 pm so
like that?
it will duplicate the first two existing options
this option is less natural, but still acceptable if punctuation is restricted:
alee001
Post by alee001 »
like that?
The .jpg attribute is just a data type and doesn't need to be considered, but an incorrect name will affect sorting.
test
test的副本
test的副本(1)
test的副本(99)
or
test
test (copy)
test (copy 1)
test (copy 99)
we have these options
<Filename> - Copy (#)
Copy (#) of <Filename>
in 1.9.9, here is what is used in chinese
'<Filename> - Copy (#)' => <name>-副本 (<number>)<ext> (file-副本 (2).jpg)
'Copy (#) of <Filename>' =>的副本(<number>)<name><ext> (的副本(2)file.jpg)
in 1.9.8, it was
'Copy (#) of <Filename>' => <name>的副本(<number>)<ext> (file的副本(2>).jpg)
So for the second option, what is better?
'副本 (2) file.jpg' or 'file的副本 (2).jpg'
alee001
Post by alee001 »
Adding any word before the file name is incorrect. Using "-copy (#)" or "-副本 (#)" after the file name, as is common in Windows, is quite clear.
mantis3d
Yahoo Messenger: goldenmantis2000
Post by mantis3d »
alee001 wrote: Tue Jan 13, 2026 12:48 pm Adding any word before the file name is incorrect. Using "-copy (#)" or "-副本 (#)" after the file name, as is common in Windows, is quite clear.
Agree.
alee001
Post by alee001 »
Regressed update. :?
alee001 wrote: Sat Jan 24, 2026 6:50 am Regressed update. :?
in 1.9.10 its changed
alee001
Post by alee001 »
xnview wrote: Mon Jan 26, 2026 7:01 am
I want to make it clear that v1.9.9 and v1.9.10 are both wrong, and v1.9.8 is the correct version to change the name.
