Double-clicking on preview doesn't switch to viewer.
ebi
Post by ebi »
This happened three times already since yesterday, that's when I installed the program. When I left double-click on the preview image it doesn't switch to the viewer mode. It works fine for a little while then it just stops working. If I delete the xnview.ini file then everything's back to normal. Is there a permanent fix for this?
Re: Double-clicking on preview doesn't switch to viewer.
ebi wrote:This happened three times already since yesterday, that's when I installed the program. When I left double-click on the preview image it doesn't switch to the viewer mode. It works fine for a little while then it just stops working. If I delete the xnview.ini file then everything's back to normal. Is there a permanent fix for this?
Strange, and what do you have in option/General/Switch mode/ ?
