... what's the difference between the two?
Moreover:
Is there a way to add a directory including all its subdirs
with one command?
Options / Catalog / "Import folder" vs. "Add folder"
nji9
Re: Options / Catalog / "Import folder" vs. "Add folder"
"Add folder" in Settings>Catalog??
nji9
Sorry, the correct location is Tools / Settings / Catalog for both.
In Catalog directly: "Import Folder",
in Catalog / Excluded/Included: "Add folder".
What's the difference between them?
And second question:
Is it possible (by one of them) to include a folder with all its subdirs
without having to visit all directories?
import all files info/metadatas in catalog, it imports files+subfolders
Add a folder that must not be added in catalogin Catalog / Excluded/Included: "Add folder".
nji9
you can include "d:\folder" and exclude "d:\folder\subfolder"
nji9
Weird... isn't it
BTW
A mean to prevent dumb questions (like mine
) might be to provide tooltips
(for every GUI element).
As there probably will never be a docu for XnViewMP...
BTW
