Batch Convert : CSV/TSV Log
meteorquake
Post by meteorquake »
It would be helpful to have a batch convert log in TSV or CSV format, as it's much easier to study the conversion metrics in a spreadsheet program and spot any matters to focus on.
I think there are several ways this could be done, for example if it wrote the current log and also a CSV-type one, the user could then choose which one was wanted. Alternatively a setting where you specify the format type(s) (maybe some people will want both).
The converter could have an "Open Log" button.
Either way I think any solution with a CSV/TSV output choice will be a great help.
