browser: spacing between rows
geoffm
Post by geoffm »
Is there a way to reduce the empty space between the rows in the browser? an awful lot of space is lost, about 30%
I think I went through all the settings but maybe I missed something
Re: browser: spacing between rows
there is no thumbnail cell vertical auto sizing like in win file explorer
the space is only 'empty' because your images are horizontal, vertical/square images will use it in full
however, you also can change thumbnail size to fit your horizontal images:
1. change Custom thumbnail size in Settings>Thumbnail>Appearance
2. select Custom in Browser>View>Thumbnails size
geoffm
Post by geoffm »
So, the empty space isn't between the rows, it's inside the reserved space for the thumbnails because the thumbnails are shrunk to fully fit space instead of being cropped.
How can I change the thumbnail ratio then?
I change the custom thumbnail size in the settings and nothing happens.
current ratio is way too square, the most common image ratio is 16:9 not 5:4
