This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fi
cornstar
Post by cornstar »
XnView MP suddenly stopped starting on my Windows 11 PC.
When I try to launch it, I immediately get this error message:
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Reinstalling does not fix the issue.
System:
Windows 11 64-bit
XnView MP 64-bit (current version)
What happens:
The error appears immediately
What I already tried:
  • Uninstalled XnView MP completely
  • Reinstalled it
  • Rebooted Windows
Same error every time
Thanks for any help.
jkm
Re: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application ma
Post by jkm »
Make sure you're running 1.9.10, which was just released to address startup crashes. If the problem persists, report back here to confirm your version number.
cornstar
Post by cornstar »
That indeed did the trick, thanks!
jkm
Post by jkm »
cornstar wrote: Wed Jan 21, 2026 8:05 pm That indeed did the trick, thanks!
Great!
That's why it's not good when people report "current version" as the version they're running. When you reported this, you were already a version out of date. :)
Pierre is tricky, and you have to keep an eye on that announcements page!
