Warning for probably unintended category filter setting
nji9
Post by nji9 »
If "Match mode" is set to OR:
If checking a filter for a category not set
while for another category filter is set already (or the other way round)
there might be given a warning/ notice,
as this might probably be an unintended match mode setting
... which gives wrong results (unnoticed?).
nji9
Re: Warning for probably unintended category filter setting
Post by nji9 »
This suggestion holds even if my other suggestion
viewtopic.php?p=211416#p211416
should be realized.
sorry but what do you means?
guess the same as here
viewtopic.php?p=205833#p205833
