High DPI GUI chinese text is very jaggy
BK201
Post by BK201 »
windows 10 x64 21H2
200% DPI scale up
1.8.8 -> 1.9.10
version 1.8.8 might be ok (overwrited and forget to backup so can't check rn)
with the new version I noticed the text is ugly immediately
to compare, I wrote same text in the windows notepad.exe with same font familiar and similar font size
Re: High DPI GUI chinese text is very jaggy
BK201 wrote: Sun Jan 18, 2026 11:46 am version 1.8.8 might be ok (overwrited and forget to backup so can't check rn)
Please you can try it here
alee001
Post by alee001 »
Just passing by…
Many Simplified Chinese software programs exhibit this issue (thickness of strokes) due to different system fonts.
I use Traditional Chinese, and MP's strokes are actually clearer than Windows fonts. If MP's font is too thin, it can even make the text harder to read.
I hope the Chinese font and custom size can be improved.
BK201
Post by BK201 »
xnview wrote: Mon Jan 19, 2026 6:29 am
Thanks for the files, seems I didn't notice this for years
after many tests, that last good version is 0.88
BK201
Post by BK201 »
Hi I just found out myself
It's Qt's fault
Following guide from this article, then it looks smooth as hell now
Method 1
Place a qt.conf file in the same directory as the executable (.exe) or edit existing one, add the following content:
[Platforms]
WindowsArguments = fontengine=freetype
Method 2 (Recommended)
Settings -> Advanced system settings -> Environment Variables
Variable name: QT_QPA_PLATFORM
Variable value: windows:fontengine=freetype
fxxk qt
