How to update the import?
artsi
Post by artsi »
XnViewMP appimage 1.9.10
I have my catalog with about 12,000 photos. It's divided in:
- people
-- family
-- friends
-- others
- places
When I add add more photos to the directory that these photos should belong to, they don't show in the browser.
How should I update these folders?
Thanks
Re: How to update the import?
you don't see new files added in folder when browsing it?
artsi
Post by artsi »
xnview wrote: Thu Jan 22, 2026 9:23 am you don't see new files added in folder when browsing it?
I'm not sure which browsing you are asking:
- using thunar or bash, I see the files, they are in the proper folders
- using xnviewmp browser window, i do not see them
or I must be missing some operation
Thanks
artsi wrote: Thu Jan 22, 2026 4:48 pm - using xnviewmp browser window, i do not see them
and you files in other folders?
artsi
Post by artsi »
xnview wrote: Thu Jan 22, 2026 4:51 pm
All the other files are their folders and I can see them in the xnviewmp browser window.
Merci
do you have checked rights?
artsi
Post by artsi »
xnview wrote: Fri Jan 23, 2026 6:50 am do you have checked rights?
Yes, they are ok:
$ ls -alF tofino-20251005-2*
-rw-r--r--  1 froggy froggy 19533987 Oct  5 03:53 tofino-20251005-2747.ORF
-rw-r--r--. 1 froggy froggy 19550143 Oct  5 03:54 tofino-20251005-2748.ORF
-rw-r--r--. 1 froggy froggy 19474131 Oct  5 03:55 tofino-20251005-2750.ORF
-rw-r--r--. 1 froggy froggy 19414877 Oct  5 03:55 tofino-20251005-2754.ORF
-rw-r--r--  1 froggy froggy 19552250 Oct  5 03:55 tofino-20251005-2755.ORF
-rw-r--r--. 1 froggy froggy 19702982 Oct  5 03:58 tofino-20251005-2756.ORF
-rw-r--r--  1 froggy froggy 19327769 Oct  5 05:07 tofino-20251005-2792.ORF
-rw-r--r--  1 froggy froggy 19327769 Oct  5 05:07 tofino-20251005-2792_v1.ORF
-rw-r--r--  1 froggy froggy 18880049 Oct  5 05:07 tofino-20251005-2794.ORF
-rw-r--r--  1 froggy froggy 20140466 Oct  5 06:01 tofino-20251005-2814.ORF
-rw-r--r--  1 froggy froggy 19009857 Oct  5 06:02 tofino-20251005-2850.ORF
Merci
jkm
Post by jkm »
artsi, are you saying that in the XnViewMP browser window, you browse to a directory, and you see some images in that directory, but not others in that same directory?
If so:
1. Check your filter settings in the browser. Set it to ALL
2. Try the Synchronize Folders button in Tools->Settings:Catalog
3. If the problem persists you might need to use the "Maintenance" button
artsi
[Solved] Re: How to update the import?
Post by artsi »
jkm wrote: Fri Jan 23, 2026 8:42 pm artsi, are you saying that in the XnViewMP browser window, you browse to a directory, and you see some images in that directory, but not others in that same directory?
If so:
I don't think that I made myself clear.
Last year 10-oct-2025, I created the directory and added a few hundred photos:
1. 10-Oc-2025: xnviewmp: no problem
2. 17-Jan-2026: i added (with thunar: the xfce file manager) 75 photos to the directory, including the tofino* images.
3. Later that day, I wanted to rate these photos in xnviewmp and they were nowhere to be seen.
4. The filter was: images only
I just ran:
Tools -> Settings:Catalog -> Synchronize Folders and now it works. I can see the photos that I added to the directory on the 17-Jan-2026.
Now, I know.
Merci
jkm
Post by jkm »
Glad it worked.
Out of curiosity, was this directory on locally mounted storage (your internal hard drive), or was it a remote filesystem (nfs/cifs/or some other Network Attached Storage)?
artsi
Post by artsi »
jkm wrote: Sat Jan 24, 2026 2:27 am Out of curiosity, was this directory on locally mounted storage (your internal hard drive), or was it a remote filesystem (nfs/cifs/or some other Network Attached Storage)?
Local:
$ lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
nvme0n1     259:0    0   1.8T  0 disk
└─nvme0n1p1 259:1    0   1.8T  0 part /evo    ««««
nvme1n1     259:2    0 953.9G  0 disk
├─nvme1n1p1 259:3    0   976M  0 part /boot/efi
├─nvme1n1p2 259:4    0  57.2G  0 part /
├─nvme1n1p3 259:5    0  31.5G  0 part [SWAP]
└─nvme1n1p4 259:6    0 864.2G  0 part /home
Merci
