1.9.10 Filesize unit not saved in search preset
yudhi717
Post by yudhi717 »
XnView: MP 1.9.10 - 64 bit
OS: Windows 64bit
Effect: when choosing preset with filesize the unit is always bytes
1. save preset with filesize & any unit except bytes
2. load the preset, unit reset to bytes
Actual behaviour (bug): filesize unit is not saved
sample preset saved in the search.ini
4000<={"all":true,"case":true,"db":false,"fields":[{"name":"width","op":"less_than_or_equal","value":4000},{"name":"height","op":"less_than_or_equal","value":4000},{"name":"filesize","op":"greater_than","value":1024}],"filename":"*.*","pathname":"","recurse":true,"regexp":false}
Re: 1.9.10 Filesize unit not saved in search preset
This problem is supposed to be fixed in XnView MP 1.10.1. Please check and confirm the bug fix here.
