A quick filter in the Catalog filter panel would be great when having a lot of categories so less scrolling needed.
Thank you.
Suggestion:
Catalog Filter - add quick filter
wagbamem
KLE-France
Re: Catalog Filter - add quick filter
A special login just to add my +1.
Indeed, the Quick filter's absence from the Catalog Filter has always baffled me, as it is already capable, at least partially, of searching the catalog.
I would add that if implemented in the Catalog Filter, the Quick filter should be able to filter to any of the former's aspects: categories, yes, but also ratings, color labels, properties, bref, all the Catalog Filter offers.
to find quickly a node?
wagbamem
Good idea.KLE-France wrote: Mon Jan 26, 2026 9:04 am I would add that if implemented in the Catalog Filter, the Quick filter should be able to filter to any of the former's aspects: categories, yes, but also ratings, color labels, properties, bref, all the Catalog Filter offers.
Yes, and sub-nodes.
Also, based on KLE-France's idea, ability to select main nodes, in which the search(filter) will be.
Something like this maybe? When the little magnifiyng glass popup is open:
