I tried looking and couldn't seem to find it so I'm asking here. Hopefully I wasn't wrong.
I know you can "Save" a session by closing XnView MP. It'll save all opened tabs.
But there doesn't seem to be a way to save the session without closing the app.
Will it be possible to add that feature and also the possibility to restore a saved session (after opening the app).
Also, sometimes I have a big session with dozens of tabs but don't need them all to be "loaded" at the moment.
Is it possible to "load/unload" tabs that aren't needed right at this moment?
Because a big session can take a lot of RAM.
Please and thank you.
Save/Load Session
Re: Save/Load Session
This problem is supposed to be fixed in XnView MP 1.10.1. Please check and confirm the bug fix here.
