Set wallpaper - modes - unify XnView and XnShell
XnViewMP 1.9.10
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Set wallpaper
there is some inconsistency between fitting modes in XnView and XnShell
  • XnShell
    - use same modes as in XnView
  • rename
    • Centered → No fit
      the biggest difference between modes lies in the fitting area, not in the origin
      so it is better to specify the fitting aspect of a given mode
    • Tile from center → Tile
      center is default origin point, it does not need special highlighting
    • Tile → Tile (top-left)
      indicate origin point when it differs from default
Modes
Mode             Down    Up        Crop     Ratio    Full      Repeat Origin
No fit ✖ ✖ ✖ ✔ ✖ ✖ Center
Fit ✔ ✔ ✖ ✔ ✖ ✖ Center
Fill ✔ ✔ ✔ ✔ ✔ ✖ Center
Stretch ✔ ✔ ✖ ✖ ✔ ✖ Center
Tile ✖ ✖ ✖ ✔ ✔ ✔ Center
Tile (top-left) ✖ ✖ ✖ ✔ ✔ ✔ Top-left
Legend
Down - downscale large image
Up - upscale small image
Full - cover entire screen
Ratio - keep aspect ratio
Repeat - image is tiled to fill screen
Origin - reference point for placement or tiling
Example
  • fitting modes
Related
