NConvert support for Aarch64 [ARM64] environment?
Sathian
Post by Sathian »
Currently, I have a licensed NConvert software, which will be used to convert TIFF files to PDF. The NConvert package is supported in the x86_64 environment, whereas it is not supported in the Aarch64 environment.
Could you please provide guidance on this issue?
Re: NConvert support for Aarch64 [ARM64} environment?
Currently ARM64 version is not available but i'll build one
Sathian
Post by Sathian »
xnview wrote: Fri Jan 30, 2026 8:14 am Currently ARM64 version is not available but i'll build one
Could you please share the estimated timeline required to provide a build for the ARM (aarch64) environment?
Re: NConvert support for Aarch64 [ARM64] environment?
Please check this version
Xonev8
Post by Xonev8 »
Morning! Thanks very much for making this version, its work on Termux running Debian Bookworm Arm64 with proot. Saved my life! Thanks for all efforts! 8)
