{Folder name[~ ~-]}-# not working
KoolPal
Post by KoolPal »
Perhaps I am unable to get this right - so please bear with me
I am using XnConvert Portable Version 1.106.0 - windows x64 (Oct 12 2025) - Libformat version 7.228
I am trying to get output as {Folder name[~ ~-]}-# - meaning - replace space with hyphen for naming the output files
I checked
You can replace a word by another by using [~xxx~xxx]
eg.
• {Filename [~img~out]} => out_example_105
from viewtopic.php?t=48554
as well as tried to understand from viewtopic.php?t=47074
What I see - example
Folder name = Downloaded Photos
If I use just {Folder name}-# - I get
If I change it to
{Folder name [~ ~-]}-# - I get
What am I doing wrong here?
Is there any other way to get folder and replace space with hyphen using
Please guide.
Thanks a lot.
Re: {Folder name[~ ~-]}-# not working
This problem is supposed to be fixed in XnView MP 1.10.1. Please check and confirm the bug fix here.
KoolPal
Post by KoolPal »
xnview wrote: Tue Feb 24, 2026 8:42 am This problem is supposed to be fixed in XnView MP 1.10.1. Please check and confirm the bug fix here.
Hi.
Thanks. Would you kindly update XnConvert with this fix too? We use only XnConvert as that is all that is required for occassional use.
Thanks again!
yes soon
KoolPal
Post by KoolPal »
Thanks a lot.
We will await that fix in XnConvert as we don't use XnView MP - it is an overkill for our needs.
Really appreciate your good work! Best wishes!
