Can there be a background program to monitor the folder?
cjyaaaaa
Now, if I accidentally click on
, the software closes and cannot watch the folder. It would be great if there was a program like XnConvert Helper that could continuously monitor in the background.
Re: Can there be a background program to monitor the folder?
Monitor for what, if it isn't a silly question...
And what action would you want to occur, are you possibly referring to the XnConvert / XnView MP Batch convert 'Hot folder' folder watching action?
cjyaaaaa
My point is about the issue with the hot folder, because now it can't watch the folder if you close the window, if I'm not mistaken.cday wrote: Thu Feb 05, 2026 5:27 pm Monitor for what, if it isn't a silly question...
