When I try to change the date/time, the error message shown in the image appears.
The cause seems to be the long file/path name.
When I rename the photo to ‘1.jpg’, the error does not occur.
Drag and drop to MS Word does not work either.
Here, too, the file name is too long.
Interestingly, Windows automatically shortens the path to C:\EIGENE~3\2021\20AEB1~1\2021-0~2.
If you try to open the file from MS Explorer in Word, there are no problems.
Error when changing the time/date with long file names
svennbg
Re: Error when changing the time/date with long file names
which option do you have under the error dialog?
svennbg
Please find attached the screenshot.
yes
currently an issue with exiftool and creating long filename
do you have always the problem in 1.11.2?
svennbg
Hello!
Renaming is now working.
However, the drag-and-drop issue persists.XnView passes the excessively long file path or filename to other programs, whereas Windows uses the short version.This problem also occurs when dragging and dropping items into the browser.
Kind regards
Kind regards
