Hi group,
I am missing help file for XnView for Win3.1 (version 1.50). It is suggested in the program to download help from xnview's site, but I found nothing there. Is there any helpfile?
I have serious problems with printing - no previews in print dialog window, often "problem with printer" warnings and blank printouts. I need some resource how to solve it. Thanks
Missing Online help for 16-bit Windows
Re: Missing Online help for 16-bit Windows
The Online help for XnView is available as .chm file (Compiled HTML Manual), but .chm files are not supported on Windows 3.1 We try to find a solution for this and perhaps provide HTML files or HLP.PetrH wrote:I am missing help file for XnView for Win3.1 (version 1.50). It is suggested in the program to download help from xnview's site, but I found nothing there. Is there any helpfile?
The Online help will help you how to use XnView, but I doubt that it would help solving your problems. Your current problem description sounds like an "out of memory" problem. Does the problem occur always or only sometimes?PetrH wrote:I have serious problems with printing - no previews in print dialog window, often "problem with printer" warnings and blank printouts. I need some resource how to solve it.
