Feature Requests for Slideshow (Manual navigation, resizing, and animation handling)
cellen
Post by cellen »
Hi there,
I have a few feature requests for the Slideshow in XnView MP. It would be great if the following could be considered:
  • Option for manual navigation while using "Use Timer": Currently, when "Use Timer" is enabled, mouse clicks or wheel actions do not allow manual navigation to the previous or next image. I would like an option to enable manual mouse navigation even when the timer is active.
  • Manual window resizing: Even when a specific size is set for the slideshow, it would be very helpful if the window could still be manually resized using the mouse.
  • Handling of GIF/WebP animations: When playing animations that are longer than the specified timer duration, I would like an option to choose between:
    • Moving to the next image only after the animation finishes.
    • Prioritizing the set timer (moving to the next image even if the animation is still playing). If possible, please add this setting to both the standard Slideshow and the Quick Slideshow.
Thank you for your hard work on this excellent software!
Note: I am using a translation tool to write this, so I apologize if any parts are unclear or sound unnatural.
