Creating a link (.lnk) to an image file
svennbg
Post by svennbg »
It would be very helpful if you could also create a link (.lnk) in xnview (not just in Windows Explorer).
Thank you
svennbg
Re: creating a link (.lnk) to (image) file
Alt+LMB drag should create shortcut
mopperle
Re: Creating a link (.lnk) to an image file
Post by mopperle »
I would also like to see a way to create links for a bunch of files via the context menu.
What I'm doing:
I'm rating pictures for a book. Then I filter after the rating, mark all files and use the context menu "Copy To..." to copy them to a workfolder. Now instead of copying them I would like to create links in that folder. This would save space and time.
mopperle
Post by mopperle »
user0 wrote: Thu Feb 12, 2026 6:36 pm +1
Bringing this up again. Alt+LMB works only between 2 Windows Explorer windows, but not between an app and Windows Explorer.
