XnViewMP 1.9.10
Windows11 (25H2), display resolution 3840x2160, dpi scale scaling 150%
Viewer - histogram
0. prerequisites
- default settings (Histogram disabled)
- have few images in folder
1. open any image in Viewer via double-click in win file explorer
2. press H to show Histogram
3. click on Histogram
it will cause navigation
LMB - prev file
RMB - next file (and context menu)
issue is not consistently reproducible
steps 1–3 may need to be repeated several times, potentially with different images
1.9.10 - viewer - histogram - navigation issue
jkm
Re: 1.9.10 - viewer - histogram - navigation issue
I can confirm this bug exists.
It can be quite difficult to reproduce.
The first time I had to try 5 different images before the bug occurred. When it happens, you can keep switching images with repeated clicks on the histo.
When I tried to reproduce again, I went through 20 images and it didn't do it at all.
