Cannot adapt software page to my computer screen
Globiwan
Post by Globiwan »
Hi All,
I have been using XnView for years and years and have now many problems with MP (today 1.9.10).
Mainly, when I open XnView, I do not have like with any other program - Windows - on the top right corner an X (to close), one or two squares (to take the full screen or part of the screen of my display) or a bar _ (to minimise).
Ok, I can live without that but somehow I made it so that the XnView window when open is bigger that my computer screen and I cannot reduce it. I can only move it around with the top bar. I tried all the menus and its all about my pictures. Couldn't find anything about the window of the software.
Thanks for your help,
Re: Cannot adapt software page to my computer screen
you have not the title bar of window?
Globiwan
Post by Globiwan »
xnview wrote: Fri Feb 13, 2026 2:12 pm you have not the title bar of window?
No, I have a top bar all the length with a tab on the left written "Explorateur" (in French) and a black cross in a small red square.
Below I have another bar with: files / edition / display / etc.
I use to have a standard title bar but lost it with MP version.
Thanks
Globiwan
Post by Globiwan »
Do you speak French, Pierre ?
Because I use this great soft in French as all my cameras are in French...
Globiwan
Post by Globiwan »
Just in case, here are the printscreens of the top of XNview.
Cannot see the bottom as I can't drag the software high enough.
donc vous n'avez pas la barre de titre, regardez dans le menu Vue>Barre de titre
Globiwan
Post by Globiwan »
xnview wrote: Fri Feb 13, 2026 4:32 pm donc vous n'avez pas la barre de titre, regardez dans le menu Vue>Barre de titre
Génial, résolu en deux click et ça faisait des jours que je me prenais la tête :D
Merci !
