Batch cropping
alee001
Batch cropping
Post by alee001 »
It is recommended to change the entry mode to "Crop" under "Create". Users can customize the image size by trimming it individually or in batches, zoom in to select the range, use the arrow keys to fine-tune the position, and output images in a custom format with the option to retain the original image.
P.S. It can even incorporate image segmentation functionality.
