XnView MP - Multiple images open
blkcrow
Post by blkcrow »
In XnView classic I was able to open multiple images and resize the windows so I could view them side by side. I'm using XnView MP now and can open multiple images but can't seem to figure out to resize the windows so I can view them side by side. I see the X to close the window but no minimize or maximize/restore buttons. I checked through the settings and couldn't find anything. Can anyone help?
Re: XnView MP - Multiple images open
Old MDI client is not supported in XnView MP
blkcrow
Post by blkcrow »
Oh no. That's depressing. :(
Thank you for the reply.
blkcrow wrote: Wed Feb 18, 2026 3:21 am can't seem to figure out to resize the windows so I can view them side by side.
you can open 2 instances of the app
blkcrow
Post by blkcrow »
True, but that still limits me to two images at a time. I'd like to be able to open more, it helps with my work.
jkm
Post by jkm »
You can view up to 4 images simultaneously using the Compare function. Select the images, then Tools->Compare.
blkcrow
Post by blkcrow »
Did not know that. Thank you!
