Cropping Selection Deviation (Any Version)
alee001
Post by alee001 »
When you select an area for trimming with the mouse, if you drag the edge with the right click, you'll notice a shift between the selected position and the actual position after releasing the right click. This results in a 1-2 pixel error after trimming. This only occurs on the top and left edges.
This issue persists; please improve it.
Re: Cropping Selection Deviation (Any Version)
any edge? no shift here
alee001
Post by alee001 »
xnview wrote: Wed Feb 18, 2026 3:51 pm any edge? no shift here
Using a white-bordered image as an example, when cropping the four sides, only the top and left lines will have deviations.
alee001
Post by alee001 »
If you trim the top or left side, you'll notice that the dotted line shifts by 1 to 2 pixels when you release the left mouse button (this doesn't happen at the bottom or right side), and the shift is more noticeable when cropping at full size.
alee001
Post by alee001 »
The problem persists even after updating to v1.10.2; perhaps it's an operational design issue?
