Hi!
I would like XnView MP to have a picture-in-picture (PIP) viewing mode, where the selected image is displayed in a small window with a minimal interface that floats above all other programs, including other XnView windows.
This feature would be useful when working with visual search, comparison, browser, or graphics editor.
I think the implementation would be as follows: it would be similar to the full-screen view feature, launched by clicking a button in the toolbar or selecting it from the menu. The XnView window turns into a small rectangle with an image, without an interface (there may be a shadow and slightly rounded corners). The window can be moved by clicking on it and dragging it. The size of the window can be changed by dragging the edge of the window. At the same time, the selected zoom mode is preserved in the window.
When you hover the mouse over the window above the image, a minimum of interface icon buttons are displayed: the exit button, previous and next, one or five zoom buttons (in, out, 1:1, fit width, fit height, fit entire image), and possibly rotation (without changing the file).
Picture-in-picture (PIP) image viewing mode
vovkasolovev
jkm
Re: Picture-in-picture (PIP) image viewing mode
It's not exactly what you want, but the app already has similar functionality built in.
You can use the Compare function.
1. Select 2 images, then do Tools->Compare
2. Click one of the side-by-side images that you want to change.
3. Next, in the filmstrip where thumbnails are shown, click the next image you want to see.
4. The main image you first clicked on will change to the new image selected with the thumbnail.
At this point, you can use left-arrow/right-arrow or PgUp/PgDn to continue to change the image. The other original image will remain on the screen for comparison.
It's not a Picture-in-picture, but otherwise it provides the functionality you seek, including zoom in/out.
Hopefully this helps. Good luck...
you need proper Frameless (borderless) mode (like in Nomacs, ImageGlass), not this..vovkasolovev wrote: Wed Feb 18, 2026 9:09 pm I would like XnView MP to have a picture-in-picture (PIP) viewing mode, where the selected image is displayed in a small window with a minimal interface that floats above all other programs, including other XnView windows.
alee001
Passing by…
I think your purpose is to compare or reference images. My suggestion is similar to the following:
viewtopic.php?t=49688
vovkasolovev
No, the point is not to compare and view several images in XnView itself. The point is to have an image as a reference constantly in view when working with other programs.
vovkasolovev
Splitting the screen or aligning windows takes up a lot of screen space and cuts off the interface of other programs. That's why I suggest having a window that floats above everything else.alee001 wrote: Thu Feb 19, 2026 7:44 am I think your purpose is to compare or reference images. My suggestion is similar to the following:
vovkasolovev
I find XnView to be the ideal program, covering practically all my needs in the area of image viewing. Overall, I am familiar with various solutions; there are many professional programs and simple tools for working with references, such as Pureref. Therefore, I would like to see this feature included in XnView, rather than having to install another program separately for the purposes of a single feature.
