MacOS Crash with 1.9.10
rayray14
Post by rayray14 »
I recently updated to date 1.9.10, running on MacOS 26.3, and XnView crashes on load. I've already submitted the dump, but can dig it up and attach here if it's useful.
I've also tried to remove the software completely, delete these files/folders, and re-install to no avail:
~/Library/Application Support/XnView
~/Library/Caches/com.xnview.xnview
~/Library/Preferences/com.xnview.XnViewMP.plist
I appreciate any help!
jomamu
Re: MacOS Crash with 1.9.10
Post by jomamu »
No problems here with XnView 1.10.1 (this is the latest) on MacOS 26.3.
Can you test whether 1.10.1 works for you?
rayray14
Post by rayray14 »
Where can I get that version? The one on this page still shows 1.9.10:
https://www.xnview.com/en/xnview-mp/
rayray14 wrote: Mon Mar 02, 2026 6:43 pm Where can I get that version? The one on this page still shows 1.9.10:
Hopefully on the forum XnView MP - Announcements page... :D
Unfortunately, when new software versions are released, as they are quite frequently, all required links are often not updated immediately, use of some form of checklist has been suggested, but so far not adopted.
rayray14
Post by rayray14 »
Thanks for that!
Unfortunately, I'm still seeing a crash on launch.
rayray14 wrote: Mon Mar 02, 2026 7:20 pm Thanks for that!
could you send the crash dump, andput your username in comment?
jkm
Post by jkm »
But please do it with 1.10.2, which just came out. It fixed some bugs in 1.10.1
rayray14
Post by rayray14 »
Done, and made sure to reference my username.
rayray14 wrote: Tue Mar 03, 2026 1:45 pm Done, and made sure to reference my username.
please update to 1.10.3
rayray14
Post by rayray14 »
That worked! Thank you so much.
