1.10.2 or 3 on win 11: issue with properties of JPEG-XL files
simon
In the tab "properties", RGB jpeg-xl files (24 bits) are rated as # of bits: 8 and Color model: greys scale. Not a big issue as they are displayed normally
Re: 1.10.2 or 3 on win 11: issue with properties of JPEG-XL files
This problem is supposed to be fixed in XnView MP 1.10.4. Please check and confirm the bug fix here.
simon
With 1.10.4, all RGB jxl files are correctly labelled RGB 24 bits in the tab "properties", but in the column properties of details view, some of them are labelled "'width x height, 16M" while some others are labelled "'width x height, 256". However, after having deleted all catalog entries, all files are now correctly labelled "'width x height, 16M"
you need to 'update catalog from files'
