Version 1.10.3 - Segmentation fault
DanPF
Post by DanPF »
I have updated to the latest version without success. I am in linux Mint Cinnamon 22.3. There is an instant crash as soon as program opens. From Terminal I get the following readout:
0.35.0 (git 2dd615b) - Multimedia Development Kit. Copyright (c) 2016-2025 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: linuxmint/22.3 6.17.0-14-generic 4KB x86_64; glibc2.24/2.39 libc++220000; Clang22.0.0 (++20250929081746+eef7a7663d27-1~exp1~20250929201945.1197); 03:47:23 Sep 30 2025.
qt5ct: using qt5ct plugin
==> 1.000000 1.000000 91.793814 96.000000 (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 960 1020
ARG[] = /opt/XnView/XnView
QObject::connect: No such signal InfoPropertiesView::itemDoubleClicked(QTreeWidgetItem*,int)
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 136, 138, 133, 178'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 255'
qt5ct: palette support is disabled
qt5ct: custom style sheet is disabled
BookmarkNode::BookmarkNode : 0x37c8b020
BookmarkNode::BookmarkNode : 0x37c8ad20
BookmarkNode::add : 0x37c8ad20 to 0x37c8b020
BookmarkNode::BookmarkNode : 0x37c8b690
BookmarkNode::add : 0x37c8b690 to 0x37c8b020
BookmarkNode::BookmarkNode : 0x37c8b780
BookmarkNode::add : 0x37c8b780 to 0x37c8b020
BookmarksModel-GETICON /home/Downloads/ 2
BookmarksModel-GETICON /home/Documents/Recipes/Recipes ToDo/Images/ 2
BookmarksModel-GETICON /home/Pictures/Pics Vol26/ 2
Segmentation fault (core dumped)
I have returned to a previous version 1.9.x as this is a daily use app for me.
Dan
Re: Version 1.10.3 - Segmentation fault
please send your xnview.ini. Do you use a theme on mint?
DanPF
Post by DanPF »
1. The theme is as standard Cinnamon options except the mouse pointers which have been changed to Chameleon avail in the system repos.
2. I am using Mint-L-Dark-Teal (apps), Yaru-viridian-dark (icons), Mint-Y-Dark-Teal (desktop).
3. I am not showing the Yellow XnViewMP folders but the system ones (which work just fine in the 1.9.xx version)
4. The ini file is attached:
xnview.ini.zip
Thank you so much for your help
Dan
Is it possible to send you a test version?
DanPF
Post by DanPF »
yes absolutely
i've sent you a PM
DanPF
Post by DanPF »
Responded in PM
Thanks for the quick turn around
Dan
This problem is supposed to be fixed in XnView MP 1.10.4. Please check and confirm the bug fix here.
