Nero Burning Rom (shareware) and Toolkit (freeware)
ckit
ckit
VuDu
good to see they keep updating v6.6...
maybe they realise that many ppl will not update to the 7.0
nero 6.6->7.0 became the younger brother of the winamp 2->3
edit: goddamn that shitty yahoo tool bar spywaring everything. adobe reader and now nero.. omg.
Ad decus et ad libertatem nati sumus
Aut haec teneamus aut cum dignitate moriamur
Aokromes
VuDu
ckit
Please be aware, installing Nero 6.6.1.4 will cause compatibility problems with "DVD Shrink" Both Nero 7 and 6.6.1.4 now use NT-SPTI instead of ASPI for communicating with devices and DVD Shrink only uses APSI layer!
I recommend keeping the latest version of Nero and switching over to using both DVDFab Decrypter and Nero Recode.
ckit
Nero CD-Speed 4.50
* Added seperate Create Disc function with following improvements
o buffer level display, both graphically and numerically
o CPU usage display, both graphically and numerically
* Added option to set priority
* Added options button on main screen
* Greatly improved image burning engine
* Added menu shortcuts for burning image file
* Improved erase function
* Disc Quality Test
o Added 1x, 2x, 4x, 6x CLV and 8x P-CAV speed settings for BenQ drives.
o Enabled support for Pioneer drives
* Small improvements and bug fixes
Download:
http://www.cdspeed2000.com/files/NeroCDSpeed_450.zip
Nero InfoTool 4.03
Added support for LabelFlash
Download:
http://www.cdspeed2000.com/files/NeroInfoTool_403.zip
Homepage:
* Disc Quality Test
Download:
Nero InfoTool 4.03
Download:
Homepage:
Hi-
I Just happened onto this thread. I do use Nero 6.6.0.12, Recode and have Speed Disk 3.7.40 installed.
I probably will sound like a first time Nero user with my comments, but actually have used it for years. I don't bother doing the upgrades very often because everything works fine, and in general, if it's not broken, I try not to fix it. On the other hand, I am curious about a couple things...
I know I have used Nero recode, however I don't burn DVD often, and when I have it did not seem to require any more effort than burning a CD. I use "AnyDVD", btw, and it seems to work very well with Nero. Does Recode just load itself when needed? In other words, is it accessed through Burning ROM, or Startsmart windows?
Someone said something about Speed Disk and it having a burning engine. All the component names have me confused...Speed Disk sounds like a utility to test a drive. Is this something that is going to speed up burning in Burning ROM, or recode? I'm a little rusty on all this because I mostly use Nero for CD burning and for the Image Drive. Ever Since I got and iPod and iTunes I haven't been been using it for CD burning.
So...is upgrading any of the components going do much for me?
-HandsOff!
-HandsOff!
ckit
Nero Recode can loaded from StartSmart or from the Start -> Programs menu (it can't loaded from Nero Burning Rom)Anonymous wrote:Hi-
Nero CD-DVD Speed can be used for testing a drive or testing media for quality or errors.
You can learn more here - http://www.cdspeed2000.com/
ckit
mk.2
ckv
Re: Nero 7 Lite
I would. Nero is perfect example about what happens when the programmers are megalomaniacs.mk.2 wrote:Somebody might love this, Nero 7 Lite.![]()
http://www.msfn.org/board/index.php?act=ST&f=80&t=69886
But I think I will stick to my cut down verion of Nero 5.5 as long as it works.
ckit
Nero CD-DVD Speed 4.7.0.0 (Freeware) has been Released!
Download: http://www.cdspeed2000.com
Nero Burning Rom 7.5.9.0 and 6.6.1.6 (Shareware) has been Released!
Download: http://www.nero.com/eng/index.html
DOS386
Bloat
Right.Nero is perfect example about what happens when the programmers are megalomaniacs.![]()
Looking for alternatives ?
http://newsgroup.xnview.com/viewtopic.php?t=10795 (Ghosthunter)
