Name of downloaded file with version number in it
nji9
Post by nji9 »
Well... the title says it all :)
It would be nice to have the version number of the download XnViewMP in its name.
Because usually you have several - at least the last working - versions saved locally.
And typically want to keep it (and probably even older ones) along with the actually version.
As it is now (at least for Win) you have to add the version number in the download file
to have it identified for each new download.
Re: Name of downloaded file with version number in it
user0 wrote: Wed Jun 05, 2024 8:00 am
pulancho wrote: Wed Jun 05, 2024 7:18 am Suggestion: Please include the version number in the name of the download file.
that can be handy if done right:
1. download link must be always the same (preferably with 'latest' word in name)
2. server returns versioned file
example
nji9
Post by nji9 »
If I get you right... using "latest" has to be done by Pierre?
Still, obviously he hasn't since about 2 years :?
nji9 wrote: Sat Mar 07, 2026 1:04 pm If I get you right... using "latest" has to be done by Pierre?
Best practice, I think, but that wouldn't fix the issue you raised: probably for a technical reason there's no alternative to optionally renaming the download after it completes.
But in any case, past versions can be downloaded here.
obelisk
Post by obelisk »
since you have to type the version number when adding it to the website It can be done at the same time as typing the version number into the installer file
