Face Tag Plugin for Linux
SnowDiver
I just installed Linux on my computer. For a while, I use Windows and Linux in parallel, but plan to move completely.
I'm happy to be able to continue using XnView on Linux, but I miss the face tag plugin. How do I install this plugin in Linux? Do I need to download the plugin as package?
XnViewMP version: 1.10.3
.libformat: 7.232
Linux: Ubuntu 24.04
Thanks for your help
.libformat: 7.232
Linux: Ubuntu 24.04
Re: Face Tag Plugin for Linux
curerntly this plugin is only available for windows, but soon for MacOS/Linux
SnowDiver
Great news. Thanks for your answer and your work. In the meantime I will you the remaining windows instance for this feature.
With 1.10.5, you have the plugin
SnowDiver
Thank you, Pierre
Great news to have the plugin now.
I can open the face tagging dialogue and tag manually all persons, but automatic face detection does not work. Do I need to install another package? Or is this feature not intended when introducing this plugin for Linux?
which linux distribution do you have?SnowDiver wrote: Thu Mar 19, 2026 10:44 pm I can open the face tagging dialogue and tag manually all persons, but automatic face detection does not work. Do I need to install another package? Or is this feature not intended when introducing this plugin for Linux?
SnowDiver
Ubuntu 24.04.4 LTS (installed a few weeks ago, all packages up to date)
XnView 1.10.5, Libformat 7.232, installed as Debian package, download from Xnview.com
Facetag plugin downloaded using XnView PluginManager on Wednesday
there is a problem when decompressing plugin, you need to re-make links in folder /.config/xnviewmp/AddOnsSnowDiver wrote: Fri Mar 20, 2026 10:59 am Ubuntu 24.04.4 LTS (installed a few weeks ago, all packages up to date)
ln -s libopencv_core.so libopencv_core.so.413
ln -s libopencv_dnn.so libopencv_dnn.so.413
ln -s libopencv_imgproc.so libopencv_imgproc.so.413
SnowDiver
It works
THANK YOU
Pepelu
Sorry to but in in this topic.
I am now using the appimage release for 1.10.5, I have installed the face tag plug in but I don't know how to use it. I can see in the metadata menu the "edit face tag" but I don't see how to insert a face tag on a picture. In the metadata settings I have ticked the face tag setting.
Thanks
Thanks
Do you have made the links?Pepelu wrote: Fri Mar 27, 2026 5:48 pm Sorry to but in in this topic.
Pepelu
I hadn't made the links, I thought it was for the deb package. Now I have tried, and I get this:
Pepelu
Sorry, I've done it correctly now and works perfect.
