Missing extension when using -o to convert filenames with periods
zecanard
Skype: zecanard
Post by zecanard »
Simple steps to reproduce:
  1. Take a screenshot. It will be named something like Screenshot 2026-03-11 at 19.57.25.png
  2. Run
    nconvert -o ~/Desktop/% -out jpeg "Screenshot 2026-03-11 at 19.57.25.png"
The output file is ~/Desktop/Screenshot 2026-03-11 at 19.57.25 with no extension, despite not having specified -no_auto_ext.
Omitting -o produces an output with the correct extension. Using -o on a filename that does not contain periods also appends the correct extension.
I tested this under macOS v7.232.
Re: Missing extension when converting periods in filenames with -o
ok, right it will be fixed
