1.10.3: what's the newly added "No." column in header?
fireattack
Post by fireattack »
I can't tell what the point of it is.
jkm
Re: 1.10.3: what's the newly added "No." column in header?
Post by jkm »
Not new, it's been there.
It's simply a sequence column to give each entry in the list a number. Some people consider that helpful when creating a file list.
You can remove the column if you don't like it.
