After updating from 1.9.10 to 1.10.3, I'm experiencing two issues in the browser.
1. Can't scroll immediately after opening a folder
In 1.9.10, I was able to scroll right after opening a folder.
But in 1.10.3, it freezes for a few seconds after opening it.
While thumbnails are being generated, it keeps repeating a cycle of about 1 second of scrolling followed by a few seconds of freezing.
2. Can't do anything for a while after rating a file
In 1.9.10, I could select another file immediately after giving a rating.
In 1.10.3, the browser freezes for 1 to 2 seconds after rating.
1.10.3: Frequent freezing issues in the browser
hjaki
Re: 1.10.3: Frequent freezing issues in the browser
which filesize for your xnview.db?
what do you have in catalog filter at the top, 'current folder'?
Please edit your xnview.ini, change debug=2, and me the full logs?
jkm
Are files on NAS or locally attached storage?
Is xnview.db on NAS or locally attached storage?
hjaki
XnView.db size: 3.33GB
Current folder (Recursive)
Files: Local HDD
XnView.db: Local SSD
I cannot send the entire log file because it contains confidential work-related information.
Here is an excerpt from the log while it freezes in version 1.10.3.
During the freeze, "updateCount " was displayed in the log.
When I performed the exact same operation in version 1.9.10, "updateCount " did not appear in the log.
Files: Local HDD
GFF :: LoadThumbnail : 800 800 (0)
LOADED & CREATED
BLOB length 140
### ThumbLoaderThread :: setFirstItemToLoad
### ThumbLoaderThread :: setFirstItemToLoad ok
## updateDate 577ms
## updateCount ===> 578ms (6)
## updateCount ===> 1069ms (10)
## updateCount ===> 1393ms (0)
## updateCount ===> 1394ms
## updateCount ===> 1394ms ok
yes its the count refresh (you have not it in 1.9.10).
If you try global or 'Current folder'?
jkm
You say thumbnails are being “generated”. Do you mean generated, or loaded? Are they already cached or not? Actual generation takes some time, especially if you keep interrupting it.
Perhaps your thumbnail settings have changed.
If you want instant performance, adjust your thumbnail settings. Enable “use embedded” and disable “create from original” and “create high quality”.
Do you have thumbnail caching enabled and are those settings appropriate?
Please show screenshots of your settings pages for Thumbnail and Catalog.
hjaki
This issue did not occur with "global" or "Current folder".
This problem is supposed to be fixed in XnView MP 1.10.5. Please check and confirm the bug fix here.
