Add multiple folders to favorites at once?
Hit33
Post by Hit33 »
Thanks for the software. I want to add multiple folders to favorites at once, but that does not seem to be possible. Is there a setting that I am missing? Thanks.
jkm
Re: Add multiple folders to favorites at once?
Post by jkm »
Welcome to the forums...
No, you can't do that directly. But you can add a parent folder, and it can be expandable in the Favorites pane so you can see its subfolders. So that's like adding all the child folders at once.
To show subfolders in Favorites pane, add:
favShowFiles=true
to the [Browser] section of your xnview.ini file.
You can read more about ini file settings here: viewtopic.php?t=48925
