Hi )
If I copy files from XnViewMP to any other foldrr , I about :
callout_circle_center.svg
callout_circle_left.svg
callout_circle_right.svg
callout_cloud_center.svg
callout_cloud_left.svg
callout_cloud_right.svg
callout_rectangle_center.svg
callout_rectangle_left.svg
callout_rectangle_right.svg
callout_round_center.svg
callout_round_left.svg
callout_round_right.svg
callout_rounded_rectangle_center.svg
callout_rounded_rectangle_left.svg
callout_rounded_rectangle_right.svg
callout_segmented.svg
callout_segmented_center.svg
callout_segmented_left.svg
callout_segmented_right.svg
callout_star.svg
callout_star_center.svg
callout_star_left.svg
callout_star_right.svg
next I open folder for example c:\1 I see this files , I can select files in file browser and I see image and historgam , but if I open file for view , I can not list files next , I can see SVG files only if open per one file , but not open first file in folder and list files )
Bug with SVG format
Xn User
Bug with SVG format
Re: Bug with SVG format
set Like Browser in Settings>View>Filter
Xn User
But why ? All other formats with this settings work normaly , problem only with SVG format )
OddUnicorn
I have exactly the same problem. When viewing a svg file, I can't navigate to previous or next file (all files in current folder are svgs). I have to close the viewer and open the next svg manually, changing the filter settings doesn't help.
looks like there is some issue in Viewer filelist
to reproduce
0. prerequisites
- uncheck Exclude
filelist updated
index counter (in Statusbar) is not updated
2. restart app
3. open image in Viewer
.svg will be in filelist - OK
4. restart app
5. open image in Viewer
.svg will not show in filelist anymore
to reproduce
0. prerequisites
- have image and .svg in folder
- default settings
- Browser
Custom filter: 'Exclude' has svg svgz
- Viewer
Custom filter: 'Exclude' checked
- Browser
- uncheck Exclude
filelist updated
2. restart app
4. restart app
Xn User
In latest version 1.11.1 this problem saved
Are you serious now?
You offering instead of fixing simply hidding problem files ?
