JPEG - lossless transformation: Remove from Metadata menu
nji9
Post by nji9 »
The majority of XnViewMP's jpeg lossless transformations are not metadata modifications.
When in need of these operations you won't expect it beyond Metadata menu.
Suggestion:
Give them a menu entry for their own.
Maybe it should be beyond "File" menu, as actually it's about lossless saving.
merak2000
Re: JPEG - lossless transformation: Remove from Metadata menu
Post by merak2000 »
Fully agree.
I see it under the Image menu between the 2nd and 3rd group of items.
See attached screenshot
