XnView: MP 1.10.5 64 bit
OS: Linux Ubuntu 24.04 64 bit
In Tools/Settings/View/Fullscreen I set the following settings:
Show Toolbar: true
Floating views: false
When in fullscreen, the upper floating view is still displayed when moving the mouse to the top of the screen.
Moving the mouse to the right of the screen does not display a floating view.
When not showing the toolbar, all works fine.
However, when showing the toolbar, one need to be very careful to not move the mouse to far up, because otherwise the toolbar is hidden behind the floating thumbnails.
Please note: this is not related to XnView MP 1.10. This bug is around for quite some time (for me...).
Other settings of View/Fullscreen (just in case):
Auto zoom: Fit image to window, large only
Show playbar: false
Show info: true
Show scrollbars: false
Show toolbar: true
Hide mouse cursor: true
Background color: black
Dual monitor: Use second monitor: false
1. In Tools/Settings/View/Fullscreen I set the following settings:
- Show Toolbar: true
- Floating views: false
2. Enter full screen
3. Move mouse to the upper edge of the monitor
Actual behaviour (bug): The floating thumbnails bar is displayed
Expected behaviour: No floating view
Thanks for your great work, by the way.
Floating view unexpectedly displayed in full screen
xnvWolf
Re: Floating view unexpectedly displayed in full screen
i'm unable to reproduce, please send us your xnview.ini
Raider
I completely agree! It's a really annoying bug. The top pop-up panel is annoying—it pops up whenever I want to click on something on the regular panel.
version 1.11.6-still same problem. Windows 11, 25H2 26200.9168
I'm attaching my xnview.ini, but it's useless because I renamed it so xnview would create a new settings file—and the same thing keeps popping up.
I also renamed the folder C:\Users\Raider\AppData\Roaming\XnViewMP so it would create all the new files - no change
When going to the top, the thumbnail view opens. you can reproduce each time??Raider wrote: Tue Sep 08, 2026 7:30 pm I'm attaching my xnview.ini, but it's useless because I renamed it so xnview would create a new settings file—and the same thing keeps popping up.
Raider
yeah dude, every fucking timeWhen going to the top, the thumbnail view opens. you can reproduce each time??
with "floating views" setting disabled::: If I disable the "show toolbar" setting, both the toolbar and the top thumbnail panel are disabled. And if I enable "show toolbar," the top thumbnail panel appears on top of the toolbar.
btw its not fault of my "startAllBack" software-i turned it off and stll no changes
The problem is with 'show toolbar' setting
Raider
yeee dude, very cool!
