XnView MP 1.10.5: Moving color-labeled images with Alt+M leaves empty placeholder entries
modchi33
Post by modchi33 »
I found a bug in XnView MP 1.10.5 on Windows.
When I move images that have a color label applied, using the Alt+M shortcut to move them to another drive or folder, the files are moved successfully, but empty placeholder entries remain behind in the view. They appear as blank/ghost items, as shown in the screenshot.
Steps to reproduce:
Create a folder and place 2 images inside it.
Inside that same parent folder, create another subfolder and copy the same 2 images into it, so there are 4 images total across the recursive folder structure.
Apply an orange color label to all 4 images.
Open the Color Label filter and set it to Current folder Recursive + AND.
Select the orange label so all labeled images appear.
Select all images, then use Alt+M to move them to another folder.
When prompted, choose Replace All.
Expected result:
All moved images should disappear cleanly from the current filtered view.
Actual result:
The files are moved, but empty placeholder/ghost entries remain in the Catalog Filter results.
jkm
Re: XnView MP 1.10.5: Moving color-labeled images with Alt+M leaves empty placeholder entries
Post by jkm »
The Catalog Filter does not update "Live" for some things. Some changes require a restart of the app (this was partially addressed in a recent update) and other changes require you to switch filters to update. As in, you're viewing orange; then select red, then go back to orange and orange is updated when you re-enter it.
You'll notice that if you view the orange category in the catalog filter, and there you change a file to red, it does NOT instantly disappear. You must leave and re-enter orange. That's not a bug, it's a limitation.
I tried your test:
When set to Current Folder Recursive (the AND is irrelevant by the way; that is the boolean mode, not the scope) all the images cleanly disappeared.
When set to Global, 2 images disappeared (which is correct, since you effectively deleted 2 and 2 remain).
So I was not able to reproduce what you describe.
What happens if you switch filters in the catalog filter and go back?
