This results in image files with "disconnected" sidecars, or extraneous sidecar files.
Settings:
Default xnview.ini
Create or update XMP sidecar: enabled
Naming convention: filename.extension.xmp
Link companion files for the following actions: Delete, Copy/move/rename both enabled
Show companion files: disabled
Steps to reproduce:
1. Start with a file test.jpg that has a sidecar test.jpg.xmp
2. In Browser Ctrl-drag or copy/paste test.jpg to the same folder, to duplicate it.
3. Observe 2 files are created: "test - Copy.jpg" and "test.jpg - Copy.xmp"
4. The xmp file is named incorrectly, and so is not connected as a sidecar to "test - Copy.jpg"
Sidecar is named: "test.jpg - Copy.xmp"
Sidecar should be named: "test - Copy.jpg.xmp"
If Filter=Images, the user will not see the extraneous XMP file. The only indication of error is the missing sidecar overlay on "test - Copy.jpg"
5. If "test - Copy.jpg" is then deleted using the app, the mis-named xmp file is NOT deleted. So extra xmp files are left over.
This problem does NOT occur if Naming Convention=filename.xmp
